ThatWhiteKidWhoStrokes
Not sure if this is the right section and will ****** if needed.
Have a 2014 f250 369sxe 15 pump Midwest comp trans. Finally installing a TruTrac in the coming weeks so I'll finally get to take it to the track. I am a 2WD truck which is the challenge.
The slick I'm looking at is m&h 28x10.5x17 but I'm worried being bias ply with my radial proxes on front I'll get the sway on the top end. But I don't feel like running a normal radial will give me enough bite to be worth the money. I'm trying to go out and launch the piss out of the truck. I don't want to buy radials and be disappointed cause I can only leave on like 5lbs of boost.
What's everyone using for tire choices on 2wd trucks? I'm using the stock 17x8 work truck wheels on rear
