I can put together a gen3 setup on my build, got the DT444E HPOP rez, gear and can get a haldex pump. Is 250/200 too small for that much oil? or should a stroke out my 200/80's?
I dont believe that there is an injector that is "too small" for big oil. Simply that there are injectors where you will not see a huge improvement with big oil and you will not be taking advantage of the full benefits of big oil. However I'm sure some of the more knowledgeable guys will be along shortly to get you an answer
:whs: You can run big oil on stock injectors. It's just more oil than you need. I have a stage 2 stealth with 160/100 injectors, that's way overkill but I've got room to grow. 250/200s will need bigger than stock oil anyway.
budro runs his stock sticks in his SD with twin stealth pumps. That's pumping a pretty similar volume to what a Gen 3 is and I think he's got quite a few miles with that setup.
As long as your IPR refresh rate is set correctly where you won't get a P1211 on decel then there shouldn't be an issue. But some have issues with ICP ABOVE desired when you let off of the throttle
I get an above code if i try to hold it at 1500 or more very long. Its all choppy and cool soundin goin threw the pits though lol. Only have one tune though and its only meant for wot so i never bothered to have it tweaked.
