smoking and stumped??
6.0smokinstroker
Hey guys having a little trouble with this one. Was leaking oil into turbine side of turbo had oil in downpipe pulled turbo got the garret rebuild kit and replaced all internals after this truck runs better but is still smoking used to only be while engine wasn't to running temp but is now blowing white and or blueish smoke on take offs from a stop all the time even when warm any info would be appreciated
Gary
South Lyon Mi
Is it using oil? I have seen the arm that works the unison ring leak oil. Stiction and worn injectors could also cause smoking.
6.0xcursion
Still using oil or has that stopped? White smoke could be fuel related. Could have injector(s) or o-ring issue. Any way to run a contribution test?
