psduser1
Posting some sotp results after basic upgrades.
This truck came to me stock at 130xxx mi., and its a dd. This summer, it lived in front of 16-20k worth of gn. Did pretty decent, but I was using most of its available power!
So, a little research, and I had a 4" exhaust, Tymar intake, and PHP tunes,adrenaline hpop. Better! Sorry, no gauges
:doh:
More reading, more talking to vendors, more info.
Now, 38r, dd clutch, gages (scangauge, egt, boost), and rr. Pulling the same weight, everything is much happier, and I can see it by gauge. Gcvw of approximately 19,500 from mi to fl, set the cruise at 67 mph, the highest egt I saw was 1300 , Bills 80 horse setting. Duty cycle was 75%ish, at 2800 psi. I tryed 25 and 60 settings, similar results, sometimes better, occasionally slightly worse. This is on stock AD injectors. Obviously, the hpop is close to its limits.
Boost made it to 21 lbs, once. I'm happy with that, for now. Spoolup was at 1600-1700 rpm, pretty close to stock, which will be perfect with another charger up top to open up the rpm band.
No big numbers, not big sales type info, just a good solid, RELIABE tow rig. It has limits, but for less than 3500$, I've got all new, or as good as new parts, and a solid foundation to go bigger on.
Thoughts? Advice on the next step?
Sorry about the long post, and thank you for all your help so far.
:doh:
