Somebody School Me---- Brakes
Gearhead
Okay so after the 08 f250 axle swap on my 01, I'm looking for brakes. Unfortunately I don't know if my axles are off an 08 or 09, or 10.... I am looking at brakes and it appears that the aftermarket kits are different.
Is there a difference in brakes between the 08 and 09-10 as the kits suggest?
Dzchey21
wyoming
thats odd i dont think that i have ever seen that, let me check a source really quick and see.
Dzchey21
wyoming
i used napa pro link and crossed everything to all the same part numbers for pads, rotors and calipers, The only thing that was kinda interesting is the brakes are all the same for 2005- current except front pads, they show a difference between pads on F-250 and F-350s for whatever reason
Gearhead
I was looking at the powerstop kit and it appears one of the kits supports the 09-10 trucks only... odd
Dzchey21
wyoming
i dont really have an explination. from what i can see it should be fine but maybe im missing something .
co04cobra
WV
08-10 pads are the same iirc. There was a change early in 11, but the pad size is the same with the holding tab being a different width and that was it.
99-04 pads are for sure much different then 05-10. The 11up parts, I believe, will all interchange with a bracket change too.
Gearhead
Cool thanks guys, I'm going to check in here over the next couple of days in case somebody says otherwise.
