someone should try it
Nos_GTSR
Rexburg, ID
Getting everything buttoned back up then its coming down.
Powerstroke Cowboy
Montana
Cant wait to see how this thing looks and runs, When you are all done. I have a feeling this is going to be ONE sweet set up!!!
Sequential6.4L
Buddy of mine pulled the off his 6.0 with the front bucket Massey, all went well but sketchy for sure. you are brave my friend.
Nos_GTSR
Rexburg, ID
Ive had it running a few times its just wont build FRP so Im having II go threw the pump to make sure its 100%. On another note I might be replacing the nozzles again While going thru everything we looked at the balance rates and only 1 was where it was supposed to be.
White_monster
The great white north
Sounds good. You try a new frp sensor? I'm sure II will get it going. On the injector side of things, that sucks man but I'm not surprised they are like that. Keep us updated.
Dzchey21
wyoming
Was that with or without the adaptive fuel trim on or off.
If you let it sit and idle will.it start to run rough and misfire?
Reason I ask is these are different then duramaxs the computer is sensitive enough to shut a cylinder down even when the injector is probably close enough to pass a balance rate in a dodge or duramax
Sent from my DROIDX
Nos_GTSR
Rexburg, ID
Pump was trashed. :fustrate: Now Im going back to Idaho to pull the injectors and bring them back to Utah so we can inspect them and see if there trashed too. That was my great news of the day.
Dzchey21
wyoming
Hate to say it but dual fuelers ftw. Sorry about your luck jon that's a real ***ing bummer I feel for you.
Sent from my DROIDX
Nos_GTSR
Rexburg, ID
Ill give the II pump one more go. Id like dual fuelers but that would mean redoing a bunch of stuff and I really like how the Dirty Diesel elbow looks in there. We will be touching up the nozzles no matter what since Im pulling them and II has a freaking sweet new extrude machine.
Heavyhaul
Wyoming
Are they going to warranty it for you?
