******* SOTF beta testing
ckrueg
Belding MI
I couldn't find the actual discussion of what parameters were OTF
If you find it, link it up por favor :)
[quote name="Luke@MillerPerformance" post=1257858]EFILive type switching, I like it![/QUOTE]
Similar in implementation, identical in mounting type.
I feel that from an engineering perspective, doing it on-screen invites too many problems in general. Not to mention, not everyone wants a monitor mounted all the time, for a lot of reasons.
From a calibration standpoint, the method we are using internally to the ECM allows more flexibility than changing RAM values to alter fueling.
When you flip the switch on our device, torque calculations, fueling, timing, turbocharger parameters and everything else relevant will stay synchronized. No glitchyness, no weird drivability concerns, etc.
Page 22 of the big spart. thread in the 6.7 section said this. Sounds like everything changes.
drunk on diesel
Cool, I guess I'm still left wondering if they've implemented a custom OS, or what exactly they're changing
everything stays synchronized... but does it change? just very interested/curious
SpartanDieselTech
Timing, fueling, VGT/boost and torque management are all changed with the power levels.
There is no way to simply "cap" or change duration without affecting the other dynamics.
The only thing that cant be altered is the base file itself (lambda/smoke) and diagnostics.
Radioflyer
This is awesome to me. Coming from a dominant duramax/cummins tuning shop, it's nice to see that this is something that is finally becoming available for the PSD's.
The switch install part, where exactly do you tap into? If you don't want to release that info yet, I completely understand.
SpartanDieselTech
No tapping required. It's as easy as unplugging an unneeded sensor, and plugging our harness into the ECM harness at that connector. No having to disassemble ECM connectors, or other likewise nonsense.
Broke 20
Alaska
sub'd. just waiting for my exhaust to show up to install my engage, and patiently waiting for sotf to be fully functional!
ccmac
Texas Panhandle
As soon as the ndash is out with this tuning I'll be ********.
Y'all may have covered it in the other thread, but will you be able to disable traction control with certain tunes?
06-sixoh
Bakersfield
Not sure I can wait for the NDash. Ive got a trip from CA to TX planned beginning July, and I want to be tuned before then.
dawashi
Any update on the sotf, how is it working or not working pros cons
Jeremy @ No Limit
Athens, Ga
As far as i'm concerned it works perfectly. I haven't found an issue yet. It's up to Matt and the guys as ******* as to when they release it. I'll be getting dyno graphs for all tunes as well as a few track slips as soon as they open
08Monster
Wondering about TC also! That would convince me to switch alone.
