isootmypants
Been thinking about this and wondering if it would help gen3 issues. Since most people run a stock pump with gen3, they have romp issues and starvation issues on start up or at stops. Most people who do that, run 300/200, 400/400, etc. And since the stock pump does not have the direct volume on start up or low idle, it has some issues. If the SRP1.1 is used, would the bigger volume of the pump help the start up and low idle issues since its a bigger volume pump, and then the gen3 will aid in supplying enough oil for whatever size injector. Or will this be TOO much oil? If there is such a thing...
