stage 2 injectors .....no chip
8inchstroker
AZ
As the title says.....if im running bigger injectors and no chip,would it be possibe this is causinG SES LIGHT?
blackbetty13
yep most likely ur draining ur fuelbowl or its getting to hot i ran stage 3s witha stock turbo and this happened
CSIPSD
Bend, OR
What year truck and what kind of "stage 2" injectors...
Didnt give us much to go on...
Speak english...:cursing:
Tell me what sensor will set a SES light if "ur draining ur fuelbowl"?
Tell me what sensor will set a SES light if "getting to hot"?
ur? yep? witha???:shrug:
8inchstroker
AZ
01 ..........not sure who's injectors. Been running them for many yrs. Also has an h2e turbo.
CSIPSD
Bend, OR
With no chip or programer?
Have you always had a SES light?
Are you sure you have Stage 2 injectors?
If you do it sounds as if they are split shot stage 2, which more then likely would cause a SES light from low ICP pressures.
8inchstroker
AZ
i have never ran truck with no chip untill now...........:doh: Thanks for the responses.:thumbsup:
blackbetty13
lol ur=your. One night i was on it for to long and at the time i had stock turbo, stage 3 injectors and stage 1 tuning. i had a slight loss of power (ran out of fuel). and then the cel came on i turned truck off and popped the hood. i had never felt my engine that hot before when i went to start it back up after cooling down the light was no longer on??
Powerstroke Cowboy
Montana
So you just took the chip off and now am having trouble????
Does it start hard and idle funny???
If they are a normal Stage two injector (single shot) You will NEED a chip to run them right in a 99 and newer 7.3L. Even some 97 pickups will need specal tunning to run single shots..
Single shots take more timing at a idle to run right..
neverkickn
AR
You likely had some kind of oil related code. It wont flash the light for fuel and overheat issues alone.
mnstroker
If you run the fuel pressure low enough long enough you will throw a ses light for icp uncontrollable. I did it the other weekend when my prepump filter plugged.
Big Bore
9000ft in the CO Rockies
LOL LOL LOL
Seriously, stop huffing paint. It's bad for you.
LMAO, how will running stage II injectors without a chip cause an SES, but with a chip it won't? How will it drain the fuel bowl on stock PCM, but with a chip it won't?
I can tell you...it won't. The stock PCM fueling is way less than the chip. If you are getting an SES, you need to scan for the code.
Here's an even more interesting tidbit. You can run single shot stage II's on a stock split shot PCM, and it won't throw an SES.
mattymx
Big Bear, ca
HUH??? ICP is strictly oil related. It doesnt really have anything to do with fuel. You could have a totally dry fuel tank and you will still have the HPOP pumping oil oil through the injectors. :shrug:
Austin
Parker, CO
That's interesting. You wouldn't assume it would affect it because icp is reading from the head, where fuel shouldn't have much if any influence.
Austin
Parker, CO
Beat me damnit lol
CSIPSD
Bend, OR
I understand what it means, but your not texting your girlfriend about the next time your going to shave your head to get even with her.
Had nothing to do with the heat or the fuel pressure...
Stop posting worthless crap and learn some stuff about your motor...:cursing:
Arisley
Arlington, Texas
I remember I got the same talk from Joe way back in the day. Well about learning the motor before I talk about it anyway. I even text in full sentences.
Big Bore
LOL LOL LOL
See Blackbetty, now you went and got CSI riled, that doesn't happen often. Congratulations kid. He's probably forgotten more about the 7.3 than you'll ever know.
:badidea:
