Starts the dies
YoungMT Hick
Lake Stevens, WA
Ok so I know I have been having issues with the injectors but just checking to see if anything else may be going on. Truck was sitting for three days, started it ran for two seconds died. It did this twice then on the third time it finally came to life.
Is this something similar other people have had and what did you find out.
YoungMT Hick
Lake Stevens, WA
I also noticed the other day that I have about 100F different from each exhaust manifold. so I am assuming injector issues. Also failed injector is more noticeable when the TC is locked correct? Once the TC locks the truck shudders like crazy until up to temperature.
DieselMater86
Murfreesboro, TN
I would say injector issue with those symptoms also when you have it worked on just have them check the hpop also. I just had my whole motor went through then to find out hpop went out suddenly and now being replaced just save yourself the headache and have it checked.
