Big Bore
Well yesterday i received my T1000 in the mail from Joey ...
LOLLOLLOL
For wanting to sound like someone "in the know", you don"t "know" very much.
Yea doesn't help much when I say that then Joey tells me 3 ppl actually know lol
One of them, probably the first to know, is also without a doubt the same person you were arguing with earlier. He also just happens to be the person who designed then sold the Terminator duals to Joey.
LOLLOLLOLLOLLOLLOLLOL
Ok, I figured I would come in and explain the reasoning behind the mods so nicely published.
The first picture is not a bushing, but a restrictor. Your buddy Gary should know of this modification, becasue I told him about it back in 2004. On my personal truck, pressure was increased by a couple hundred PSI at WOT. You ask why? Simple, restricting that 92thou hole down to a 32thou orfice increases flow. That plastic check ball does not create a perfect seal when the pump builds pressure, thus losing valuable volume that can be better used towards the oil rails. I don't expect the average "Joe" to know this, because not everyone has access to a high pressure oil pump flow bench, as I do! FYI, I will not take full credit of this mod. I was told of this mod by someone that was in the 7.3 Performance at the very beginning. Old timers might remember the name "PsychoStroker" aka Bryan Kinney?
The second picture: Those "pings'" were to help keep the front pump seal in. There was also an increase in volume as well, with the front seal flipped over, because again, on the flow bench we seen an increase in volume(the front seal weeps a ton of oil when the oil is up to operating tempature). But doing this mod, would sometimes cause the internal piston slipper C ring to jump out. When that happens, your dead on the side of the raod and the pump internals are usually destroyed in the process. I would estimate 5 out of 100 failures, which I repaired/replaced at NO charge.
And picture three: It's just an emergency blow-off valve shim. I now use a Stainless steel shim. By shimming the blow-off valve, more ICP can be achieved, if necessary(around 4000psi). Every pump that leaves my shop, has a shim(Singles and Duals).
There it is.
On Edit: I NEVER said that the internals were modified. They are completely stock. So, if you have a failure or debris issues, it's STOCK.
Now the T500 and the T1000 are NOT STOCK internally.
Thank you,
Joey@TE
So I would ask...You did tell Gary....care to tell the others what Gary told you about the restrictor mod?
What mods are done to the T500 and T1000..
IMO having the info for all consumers to make a informed choice about the HPOP's available is best.
How does that increase flow, i think i would increase pressure, but restrict flow. that does not make any sense.
So you don't think when your buying a HPOP and trying to see whats best for your app that its better to know what the differences are...you would rather go on the internet and listen to anecdotal evidence of performance?
Would you rather have a back to back dyno test data log..of all the pumps available on the same truck?
So you think when your looking at having someone tune your truck or build you injectors that your magically entitled to know all the ins and outs of what they are doing and why? I wouldn't ask any of the injector builders to tell me every mod that they do to their injectors just like I wouldn't ask any of the HPOP builders to reveal every mod they do. Sure, it helps to decide what's what on the market, but then again they have all worked pretty hard to get where they are, why should they just hand out that info for anybody to use?
Datalogs, dyno tests, reliability, etc would be a better way of going about it. Personally, I don't need to see any of that to know what setup I'm going with next, but someone else may find it useful.
No offense but your stance seems hypocritical.
Do you not modify your truck? If so you most likely have the personality to dig deeper as to why something works the way it does.
Can someone go modify an hpop like stealth or Joey does?? Sure just get out your check book and have at it.
This sort of info is great for the community. If everyone can look inside an hpop and comprehend how it works and why it's modified then we are all better off.
Knowledge is what we are chasing. I bet if you line up a termy hpop and a stealth hpop there are some similaritys and some differences. Not because one is superior but because two different people built them.
There are a 100 ways to build something. 50 wrong ways, 25 right ways and 25 wats that no one has thought of yet.
