Steering Box Swap
doctorsmack03
I have a 1997 CCLB 4x4 7.3 with the 2005 suspension swap on it. My factory steering box has a crack in the pitman shaft. I coincidentally have a 2003 6.0 4x4 Excursion steering box in the garage that I figured I would swap in. I know I will need a new pitman arm, but from what I remember reading a while back I need to convert one of my power steering hose fittings. Does anybody have any more info on the swap?
Thanks
Josh@DirtyDiesels
PA
We have an 05 steering box in my buddy's 93 w/ 05 suspension. Pretty much bolts right up. Truck isn't done yet, so couldn't tell you on the lines or anything. Plus it's a fummins so its way different anyways
morefuel
Chico, California
You either need custom lines or different ends put on the stock ones. The return line I just had a flare put on the hard line out of the box and slipped the hose from the old line over. The pressure line I had another piece of line brazed on with the proper fitting from the 05 lines.
Edit. Just saw that was an 03 box. I have an 05 box.
FrankTheTank
Cecil County, MD
I've done the swap with an 05 box. Much easier due to the fittings needed to do it. I also had an 02 box but decided to go to the 05 box. I can post pics of the lines tomorrow.
morefuel
Chico, California
Not real sure what fittings ford uses. The hydraulic shop had me get the 05 lines for them to use the fittings from.
FrankTheTank
Cecil County, MD
You can use a stock SD hose that you re-bend to make work. The return hose I made from one of the obs fittings push loc and clamps. I will try to get some pics for ya
As for advantages, the pitman is longer and straighter to help with steering angles (bump steer) and more turning radius. The box also has a different steering ratio. The obs box is like a 12-1 ratio while the SD box is like 16-1. Don't quote me on the ratios tho, it's been a while. And that's what my research shows, never taken one apart to prove it.
FrankTheTank
Cecil County, MD
First drill out the frame to 9/16" if my mind serves me
Comparing bolts.
Bought this high pressure line from NAPA
Stuck it in my tubing bender just as you see on the box side
And bent straight and then added another 45* to it the other way, carefully.... and made it look like this
Either took this off the SD box or of the OBS box, I don't remember. I cut it down, gave it some more beND
Some push-loc and double clamps for the return down to the factory "cooler". Never had any issues but I do plan to change it in a later date.......maybe
97strokerHD
Old thread but have a few questions. I've put three steering boxes in my 97 in the last two years. Want to swap in a redhead but don't have the money for it right now. Would swapping a super duty box in be worth it and what would i gain from it? My steering parts keep wearing out because my tie rod rolls pretty bad. Usually those go first, then the balljoints, and then when i go to change it all I find out the steering box has play like the sector shaft bearings are wiped. Bought a machined plastic washer from ruffstuff specialties that goes in between my tie rod and drag link and is supposed to help with or eliminate most of the tie rod roll. Any help or input is greatly appreciated.
FrankTheTank
Cecil County, MD
The SD box swap will not work for you because your tie rod tapers are smaller then the ones in the SD pitman. Also the OBS pitman will not install on the SD box. Read head or PSE? Are about your 2 options for steering gear.
Fiveohmatt
when swapping to the 05 box did you have any clearance issues? with the coolant hoses? I had another guy on a different forum say he had to cut down a coolant hose outlet? But looking at the boxes side by side they look similar to me.
m j
BC Canada Eh!
there is more then one 'super duty' pitman arm. there is a large spline and a smaller spline that swaps with most common boxes. I use the smaller one in steering swaps as it is one of the longest and flattest pitmans available
easiest way to ID them is the large spline has three key splines the swapable one has 4
