I think people see the rear cylinders crack quite a bit, or even melt. But a lot of times its just a crap shoot. And the rear cylinders probably get hot due to the intake manifold design.
If you think of the intake manifold and its volume, looking at it, on the top it tapers downward in towards the center of the valley, and at the back it tapers downward to the back. Its obvious when looking at it cut apart, the front cylinders have a huge advantage at receiving airflow than over the back cylinder on each bank. With the back of the manifold tapering in the rear it really restricts the volume allowed to reach the rear cylinders. What a real improvement would be, is an intake manifold that is slightly taller, creating more volume, and is square, or in MPDs custom manifold round, all the way to the back, creating more volume, and an equal volume all the way to the rear. Only downside with this is that you most likely can not use factory appearing turbos in the valley due to the manifold not being tapered towards the valley creating the room for the turbos to fit.
