"Stop Safely Now" message.
91turbogsx
Gardner MA
I have a friend stranded at the moment when his '08 had the "stop safely now" message come up and the truck shut off. Won't restart after clearing codes. Has a SCT tuner with Erics tunes. Code u2023 popped up. Nothing else. Any idea how to get this thing running again?
Thanks in advance
Jeff@Spartan
Georgia
That is a communication code. It doesn't show up in my PDF file so I don't know what the description of it is.
91turbogsx
Gardner MA
Communication error between modules is what I came up with. Truck ended up restarting and he got home. But still curious what it was and how to prevent it from happening again.
Jeff@Spartan
Georgia
I wouldn't think so. I don't think that would result in a communication code. Something could be up with the PCM or TCM. It could have also been a freak thing and may never show up again.
91turbogsx
Gardner MA
After an hour it starts up and runs fine. I plan on checking all connections. I thought it was mainly the DPF sensors that would cause that message to appear and disable the truck?
Big Angry Hillbilly
Truck is in what's called "Failure Management Effect Mode"
Will not crank/start with the key for 1hr from time of failure.
Suspect last EGT sensor in the delete pipe. Manually jumping the starter either at the starter or at the breakout near the right hand battery will allow the truck to crank.
91turbogsx
Gardner MA
I was having him monitor all 3 of the sensors and the last one does seem to be out of whack. So hope that is the case.
Thanks
