Charles
- Joined
- May 18, 2011
- Messages
- 2,723
- Reaction score
- 30
Oh boy....
Racer, get a grip. I said that the protec sheathing melted OFF of that hose. If you knew what you think you do about hoses you would know what protec sheathing is...
Here:
It isn't the hose itself, it is an abrasion resistant cover much like what split loom or the spiral plastic looms are often used for.
Where a couple of the lines pass directly under the housing on the 38R those covers have melted away from the hose itself in a few places from the YEARS and YEARS of 1800+ degree exhaust temps. The lines themselves however have no leaks and have been on and off roughly one half of a zillion times since I made them up. If they were cracked then the contortionist twisting as the regulator dangled from them as the engine was turned upside down on the stand, or when they get thrown in the bottom of a box with high pressure oil pumps, brackets and bolts all on top of them whenever the engine has been torn down they would be leaking now. It's not as if they went on the engine and just sat there. They see an environment with not one, but two turbochargers and an exposed 3" pipe carrying exhaust straight over the engine itself and they live. That's pretty much worse-case scenario for a 7.3L engine fuel delivery application.
If you want to make up hoses that are suited for delivering fuel to a Saturn V rocket and install them on your trans cooler then that is your call. Maybe you would also like to promote beryllium cases for the 4r100 too.
If you've got a problem with stainless braided line from Aeroquip I think you need to take a couple Valium and learn to ignore the voices in your head.
Here:
