Stuttering on top end
Rmartin-97
Mcarthur ohio
I got my truck back together and have about 2800 miles on it so far. And the other night while getting on it I noticed it stutters right about the shift point like it bounces almost like a rev limiter. It's holding 23-24k on rail psi at the point it does this. It almost resembles the valves floating but it has rcd valve springs. It throws no codes or nothing. Does anyone have an idea what else I could check. Could an injector going bad cause this?
what is your fuel pressure on the low pressure side
Mesa, AZ
I think that it could be tune related, but check base fuel pressure too like sootie said.
Mesa, AZ
You would tend to figure so but it could be putting small air bubbles in and its too slight of a drop that the monitor doesnt catch it.
Mesa, AZ
So this is something new then? Or have you just not driven on this tune this way before?
If its something new i would definitely be checking for a failure instead of tuning. I was under the impression that the tunes were new...
Mesa, AZ
In theory yes, i wouldstart with base pressure though. If possible i would also make it happen when doing a power balance tosee if an ijector is dropping out.
6.4 Stroker
Rapid City South Dakota
:whs:
Also, VGT move freely?
I've seen them do some funky things when they lock up.
I think you best shot is gonna be to try to duplicate the problem with an IDS so you can look for irregularities. Nothings worse than throwing money at something that might be the problem.
Rmartin-97
Mcarthur ohio
I still haven't got to test the low pressure fuel. But I have noticed when it's stuttering it starts smoking worse. The rail drops to around 20k. And when I go to a lower tune it don't do it at all. And the issue seems to be worse when the motor is hot.
Jbird
I have this problem but i have a small exhaust leak at the manifold so i figure it was related. Mine seems to only do it at mid throttle 3 or 4th gear. I have an sct so no way to monitor rail pressure. Seems fine under wot and isnt a very hot tune either
