super duty picture thread:
STR8LINE
Barren River Lake, KY
If the trans was built, I would hook it this summer in work stock class even lol .. You only live once right?
But I'm Deffinately thinking with a turbo this thing will eat a stock trans.. I raced a PPE efi live Duramax the ther morning after work and semi boosted 4hi launch it ****ing Come Alive!! Crossed up twice in 4hi an when it got my **** Togather enough to look back I was atleast 10 trucks ahead of that Dmax.. Lol an to think the dude with the driver of it popped off an wanted to run for a bill till I quickly without hesitation took him up on the offer.. Then he back peddled. Needless to say he did Not want to get on it At All beside me after that launch.. I'm pretty sure the Stroker sent that Dmax home with it's take tucked between his legs
swinky
Eastern, Nc
Honestly I wouldn't be too worried about the trans. Those little tires and 4low 3rd gear will be easier on it than you boost launching it lol
Sent from my SM-T210R using Tapatalk
STR8LINE
Trust me if I pull it it won't be on those tires, it will be on a good set of tires and Iam currently looking for a set of 16.5 x14" wide welds and I want something like a 31" TrXuS tire..
Here is the exact tire I'm talking about I pit a set on my 96 F150 it has 351w and they're on a set of 15x12" Mickey Thompson ET drag wheels lol
I Deffinately want to do like a Gogo solenoid or someone else's, If Iam correct it puts More pressure on the clutches right?
Lysons
Paradise Valley, Alberta
Nice truck, but wrong thread.
There's an OBS truck thread in the 94-97 section.
He was just using it as an example man...
It's not even a diesel man.. It is a 351windsor F150 .. But anyways, you're correct an I appoligize for mucking the thread up.
If your going with a tire like that and plan on hooking her to the transfer sled and unless your on a loose track, your trans is gonna hate you... or it will snuff it out on a shift....
STR8LINE
So you think a little less aggressive tire then? Keep in mind Iam keeping stock gearing so Iam going to run a small diameter like 31" or 32" maybe.. Also, I don't have lockers yet either, I doubt all 4 will be pulling all the time.. They are in tho future plans tho forsure, arb out front most likely.
Whats your horse power goal? I guess with smaller diameter tires it may help or put it in 2nd gear low and leave it there...
STR8LINE
I think I will make 600+ on Fuel only.. When I get the new turbo lined out, my nozzles may hold me back tho. At the drag strip I may spray it, both water meth an N2O :) .. But in work stock it will be Fuel only.
Whatever tire I run will be Wide, on a 14" wheel. I have 12" wheels now with Nitto 420S's if they ever get here.. But I'm looking for a set of 16.5x14" wheels for the sled hook
Be fine at that hp then.... built trans is a MUST then..
emanmx11
Mico tx
The wheels are 22x10 AF Heros.
I loved your 6.0 that was this color, I plan on doing some paintmatching soon. It looked killer with that set up you had.
