Swagger Build thread
rat49f6
Vernon,NJ
frame rails on the shop floor
thats a 2 lt dew bottle ... think i went big enough??
driver's side rail mocked up
rat49f6
Vernon,NJ
back half just about finished ... still needs some finish welding and plates yet
from the rear:
from the back window:
side view:
angle shots:
rat49f6
Vernon,NJ
cut the turbo in the truck and all trimmed up around it
from inside the cab:
front the front of the truck:
rat49f6
Vernon,NJ
Jason and I got 2 dashboards out of Internatinal Loadstar trucks yesterday
the Loadstar trucks have a dash that is about 10" narrower than the Super duty so i bout two so i can section and stretch
dash cut into sections
second dash being used to mock up
sorry i had moved the pics without realizing it
rat49f6
Vernon,NJ
dash welded together on the bench
with steering wheel installed
with steering wheel up close
rat49f6
Vernon,NJ
Suicide doors 1 1/8" link ends with weld in bungs for 2" x 2" 1/4 wall
And a set of head studs from Clay
rat49f6
Vernon,NJ
got the passengers side of the dash welded up to meet the door panel
modded the factory under hood fuse panel bracket to fit in the glove box
both fuse panels installed in the dash
close ups of under hood panel
rat49f6
Vernon,NJ
the open void on the passenger's side
same void with door hung and panels on
driver's side tacked in
welds all ground smooth
rat49f6
Vernon,NJ
Jason and i got the accessories off the front of the engine and got it pulled
only 6 bolts remain untouched on the truck (other than drive train internals)
rat49f6
Vernon,NJ
front drivers side
the bar going across will be turned into a crossmember with driveshaft hoop
one side will be adjustable the other will be solid
any opinions on the set up
should i make the link bars the same length or have the lower bar longer ive heard both
minitrucker friend told me equal and a friend with a home built full 4 linked and bagged f250 (10" lift) said the one bar should be shorter to keep it from squatting
rat49f6
Vernon,NJ
mocked up the 6 link but i think the dog bone is too long so ill have to lengthen the lift bar and shorten the dogbone
also note nothing is welded in so it looks very crooked
pics of the trans tunnel finished and the firewall rebuild to make room for the turbo
rat49f6
Vernon,NJ
as of Sat night we got everything tacked into place and all bars are tacked up
we would have finished the passengers side but i misplaced a axle tab
so today we went into clean up mode
alot more parts on the ground then it looks but that is a f250 in pieces on the ground in front of my shop (minus what is upstairs)
good news is we found the tab
Cobra 19 & 54
Scottsdale, AZ
You could have body dropped the cab at the same time and not done much extra. The floor could have been left whole (more or less) without all the trans cutting. But the idea of your project is bitchin!!!
rat49f6
Vernon,NJ
u mean stock floor body dropped???
because the truck is traditional bodydropped from the factory
