Power Strokes
94-97 Tech
swapping a single injector
[QUOTE="Garbage_Mechanic, post: 1498557, member: 1610"] It all depends on how much time you want to spend. I have a vacuum set up with a piece of 3/16 brake tubing on the end of the hose that will fit through the injector hole and reach down into the piston bowl and suck all the oil out. I still spin it over without the glow plug. If I'm doing a set I drain the oil rails through the little plug under the valve cover, and also blow through and drain out all the fuel. After vacuuming all the piston bowls I assemble everything. I crank it over with the glow plugs and oil rail plugs out, fuel system assembled. (IDM fuse pulled) When oil rails are full reinstall rail plugs, and glow plugs. Crank a little bit, then install IDM fuse. It will start like there was nothing done. No driving the crap out of it for 10 miles to clear the air out. It just runs normally. For me so far this has worked great. [/QUOTE]
Latest: gahm3r
Yesterday at 4:16 PM
6.4 Tech
Latest: 03f3507.3
Yesterday at 2:11 PM
Engine and Drivetrain
Latest: ToMang07
Yesterday at 7:28 AM
B
No Start help
Latest: bismic
Yesterday at 7:04 AM
Latest: 6.0 Tech
Wednesday at 8:24 AM
Ford Power Stroke News
Power Strokes
94-97 Tech
