Let's start off with this is NOT for a customers truck. I would never ever recommend it or sell it even at their request.
With that being said I'm working out a deal on a truck that I believe needs a lifter. It's in the first stages of failure. The rest of the engine would be good to go, I plan on doing just lifters, cam, gaskets etc.
But... I do NOT want to pull the crank out. Question is, how many of you guys have successfully removed the bolts and balancer and put it back together successfully? How did you do it? Did you etch a mark or paint a mark? There is no dowel pin or chamfer correct?
I'm probably keeping the truck as it is CLEAN.
