The no no bolts discussion
DEEZUZ
NO PUKESTERS
NWI
Yea the cam gear started to flex. Might have a second person with a other pry bar and a hammer. Anyone know what timing marks have to line up? Big or small?
DEEZUZ
NO PUKESTERS
NWI
Is there a spec on the adapter? Got it all back together and got a crude dial on it and I do have a high spot, but wondering if there's a spec
DEEZUZ
NO PUKESTERS
NWI
Alright. I'm not even sure what dial i used, I just wanted to get an idea of how off it was. Still puzzles me that it can be out of round since the flange is such a tight fit. At what point are you measuring actual crank play is my question...
Thorholt
What marks did you use on the crank and cam? I am rebuilding mine and want to avoid buying the overpriced cam alignment tool, I just am going to use the marks but I haven't pulled the flywheel adapter yet.
DEEZUZ
NO PUKESTERS
NWI
Big to big. The little dimple on cam hear was 12 o clock as was the dowel on crank adapter
