The Official PSA Duramax gets Built Ford Tough!
Its a Fuelab pump. Its a nice little setup for what I am doing with it - but there are a few things I would change for the next go around. I really need to make a couple of custom filter bases to set it up the way I want it. I have a great source for Baldwin filters but for some reason the water separator didn't like the base.... it should be a direct cross.... good thing I had a few Fleetguards on the shelf too. LOL
are the bases by chance the wix 24770, and the baldwin the bf1259?
Hotrodtractor
Mingo, Ohio
***! by chance just the one filter? or have you tried more than one?
I have tried three different ones..... two are brand new and one was a used unit. I'm going to revisit it when I get a moment to figure out what is happening.... not sure if its the filter or the bases.
My intent is to machine a new pair of bases that incorporate some other features such as built in pressure regulation and air removal for the next fuel setup that I am building for the 7.3 sitting in my shop.
i was going to use those bases and filters to redo my fuel system... guess ill order the wix water separator filter instead.
what exactly was the problem?
bad12jr
When you get those made I volunteer as a test dummy.
Sent from my DROID X2 using Tapatalk 2
SEABEE08FX4
Montgomery TX
Damn, thats quite the change in the loos department. Looks pretty mean though, great stance. And thats a huge Baldwin, what PN # is that thing?
Chvyrkr
That sounds pretty awesome if it all works out.
Jomax
Arizona
Lots of little details to button up - but it moves under its own power.
I've got a couple of leaking injector o-rings... install the stack, finish some wiring, build the actual fuel pump mounting plate and align the front end - and its road trip time. :D
Wont the stack get loud towing?
907DAVE
AK
So it that the 7.3 we keep getting fed little tid bits of into about?
Hotrodtractor
Mingo, Ohio
Very nice build bud! Just noticed a few times through the thread, I couldn't see all the pics or YouTube vids. Anyhow... Subscribed!
Thanks.
The pics got all screwed up with Webshots changing their servers - I've switched things around to Photobucket and just need to update some of the thread. Not sure about the youtube videos.... I guess I'll need to go looking for broken links. lol
