EBPV and fuel bowl were both leaking pretty bad. Just finished with my EBPV delete/RR/turbo/hpop swap and cleaned up all the oil in the intake valley real good. Well, still got a leak; appears to be coming from the weep holes in the botton of my ZF. It is also coming out with enough "force" it is being thrown/blown on my new 4" downpipe right at the joint. I thought my 38R was leaking but I checked the downpipe and no oil in it at all.
I had planned to get my ZF6 rebuilt (regulator for fluid pump appears to be out) at the first of next year (bonus time) by MidWest transmissions and install a new Valair clutch. If I am going to have to replace rear main seal that would be the time to do it. Hoping it does not get a lot worse before then and I can rent the tool to remove and replace the wear ring/seal.
I would replace it sooner; I enjoy working on my truck. However, the wife complains non-stop when I spend a lot of time working on the truck. Takes away from her I guess. As you can probably tell I don't really have a question; just venting. If anyone has any suggestions/tips/hints/tricks please feel free to share them.
Thanks!
Thanks!
