Throttle percentage wire location for nxd4000
Deal80013
Hoping some of you guys can help me find the throttle percentage wire location and color. Trying to install a nitrous system. Thank you in advance.
Powersmoker
Chesapeake, Va
On my 7.3 there are three wires on the TPS sensor. (Located on the throttle pedal) IIRC it's the middle wire. Use a multi-meter, probe the wire with the key on. Mash the pedal and the voltage should jump to around 5 volts.
