reilly8282
- Joined
- May 28, 2012
- Messages
- 107
- Reaction score
- 0
Maybe 2000 miles ago studded the truck. New gaskets, heads shaved .08, new oil cooler, new ford pushrods and just installed some low mileage injectors.
I have a tick when warm. No codes, no misfires, idles fine, drives fine. Tick seems to be coming from passenger side upper valve cover. You can only hear it in the cab with the windows up. Under the hood sounds normal for a 6.0l, even outside the truck sounds normal.
When I get into some boost it normally would get quiet and you loose the injector chatter all you could hear was the exhaust. Now I loose the injector solenoid chatter and get a tick, sounds like an exhaust leak on a normal gasoline engine. I can't find any leaks around the manifolds. To me it sounds like a rocker, lifter noise but I don't have other issues associated.
Here is a iphone video, not great quality but you can hear it.
http://m.youtube.com/watch?v=AZuy4MwwtCU
Any thoughts? Thanks.
