Timkin Unit Bearing...
CSIPSD
Bend, OR
I've replaced quite a few unit bearings over the years, on my own rigs and others...
I can honestly say I have never installed a Timkin set...
Do they cost more... Yes...
Are they worth it??? I used to think not, but after installing one this weekend, without a doubt they ARE!
With the aftermarket ones, they require you to reuse your old studs (not wheel but the unit itself), and supply a new O-ring... The Timkin comes with all of this.
The pure quality of the unit is visually apparent...
BTW, I pushed this last one a little too far, I think that last 400 miles was on borrowed time. Right front had over an inch of movement top to bottom...:jawdrop:
Thanks to RiffRaff for the quality parts (and price).
dustinz85
Houtzdale Pa
Reusing those studs are a pita.. I usually spend the extra coin for Timkins.
Sent from my DROID RAZR HD using Tapatalk
Zmann
it's Timken u bone heads LOL
mustube
Austin, Tx
Moog comes with new studs. Also, at least here, Timken is cheaper at autozone than moog is at advance.
dustinz85
Houtzdale Pa
I've noticed that before, that how I got buying timkens, just because that usually what OEM is
eng53ine
Ohio
Mine fell apart in a year
02 ccsb, lariat, 7.3 auto, 4x4, 4" duals, 6637,zoodad
Krause
BC Canada, and PA USA
What was everyone buying if they werent getting timkens? I just bought some Timkens, and felt like they were pretty well priced at Rockauto, 172 each. Unless you go with the absolute cheapest ones, Timken isnt really that much more...?
Zmann
wow that is cheap you must have the older style ? I haven't found mine for under 300
II want a spare since I'm over 100k on mine
CSIPSD
Bend, OR
I got a smoking deal from Clay, but I have not seen them for under $240-$260...
I paid about $125 for the last one from Rock Auto, and it lasted 70k or so...
Krause
Is your truck an 05+? Im not sure on those ones, but for 99-04 177 is the price..
SP580205, type that into Rockauto, Timken 4 wheel ABS single rear wheel fine thread studs, 177. Plus if you spend time on FTE, you know you can get 5% off any rockauto purchase, they have a coupon code in the vendors section of FTE.
Lang
WHS. Mine was about that when I replaced 1 last year.
Zmann
bummer they are 380.oo
i did find the code thanks for that since I never visit FTE anymore because it so slow and the pages load jerky I wouldn't have seen
5% Discount Code: 9DD288B33BD485
Expires: 05/17/2014
autozone wants
Price: $696.99
i am wondering if they are all apples to apples ?
Lang
i did find the code thanks for that since I never visit FTE because it so slow I wouldn't have seen
Expires: 05/17/2014
autozone wants
Price: $696.99
Dude google it... Just did and parts geek has them for $182.35 plus free shipping......
Zmann
i did last week never found anything below 300
i will try again but mine are not the same as the -05 under
