tire size on a leveling kit?
tmillburg
i have 285s now, and i am looking for wider, you think a 305/55/20s will fit w/o rubbing, thanks
ZacPSD60
Spring, TX
Yes, you'll be perfectly fine. Those are 33" tires and the tires you have on your truck stock are usually just above 34" so no rubbing issues at all.
17BLKplat
Southern New Jersey
17BLKplat
Southern New Jersey
thats is perfect, thanks for showing me, you helped me make a decision lol
Right on!! Glad to help!
I only had to cut back a VERY small amount (3/16 of an inch) on a bracket on the driver side of the front bumper and a small bit of the inner fender plastic. Both were done to avoid issues at full lock only, otherwise not a single rubbing problem and drives as good as stock.
Can't wait to see your truck done up!
