MY 2014 does this as well every time i cut it off and when i let off after a hard acceleration . im running ******** tunes with no limit stage 2 intake. I thought it was normal. Should i get my tunes tweaked? Thanks guys.:wtf:
The change from a 4" to a 5" intake tube has a slower velocity by 55%
In other words the air is moving 55% slower through the bigger tube. This adjustment should be made via mass air flow in tuning.
Many equations to calculate that number..... I just can't get anyone to believe physics for tuners.... they just guess alot!
nope, thats totally normal.
except for the fact the tunes are adjusted for mass air flow. but you should call all the tuners up and tell them how it works with physics and such.
Obviously not correctly tuned, or people wouldn't have issues with air filter swaps. Not a bash against ALL the tuners...
What's wrong with doing a math equation to understand exactly how much to adjust the resistance reading for the MAF? Your filter you provide as a equation derivative for what little restriction it has/increased diameter of the 5" tube that floats = xxxx.xx
I did this because I have your filter setup... I know it means nothing to you, and you wish I would vanish like the rest have....
I did discuss this with patriot(when they were spart-an), they were willing to listen. You can be hard headed when one is trying to refine using YOUR product, besides just killing the check engine light!
But hey....... it's your forum right...
Is what he said NOT true?is there anything you don't know the most about ? i'm surprised anyone would listen to you at this point. there are many tuners out there , you mentioned one, and they as well have built custom files for our intake. as has been said MANY MANY times, they work better than anything else out there when properly TUNED . we can't help it when someone installs one backwards and makes a thread about it , then realizes it and disappears. and yes , this is my forum. we'll just go back to killing codes and making the most power , and leave you and the other pro's to lead the charge in the diesel world .
