Tow Truck
JoeDaddy
Gridley Ks
Its what he does...very well unlike myself. And I hate him for it LOL
I was born in a salvage yard LOL
I see he shortened the bed so it will now fit in the garage... :thumbup:
Believe it or not it fit before but just barely. When I built the shop I thought 24' was plenty wide enough. WRONG! My next shop will be 40x60.
His wife got mad at him making their yard look like a used car lot I betcha...he didn't have a choice but to make it fit in the shop!
She cracks the whip LOL
JoeDaddy
Gridley Ks
Fuel is done up top.
Engine ready to go in. We had to do this twice. The motor mounts are completely different.
JoeDaddy
Gridley Ks
Nice Joe... I'm curious about the front cover also.
Everything is bolted up, clearance everywhere. So far as I can tell it doesn't make a difference. I even kept the OBS fan, never seen 1 break. The coolant temp sensor had to be changed as well as the HPO sensor at the back of the res. Motor mounts and pads had to be changed as well as the drivers exh mani. There's an extra coolant temp sensor on the OBS 7.3 that didn't get reused. it sits to the passenger side of the water pump. It threw at 1st me but the consensus was that it was un needed.
JoeDaddy
Gridley Ks
The fuel lines are 5/16" back here and I bought 3/8" so 1 more stop at NAPA tomorrow and it should be done. The pump was moved back to the next triangular hole pattern. The mounting bracket is welded on as high as I could get it right above the trans cross member.
JoeDaddy
Gridley Ks
Got most of it put back together only to find the lower radiator tank is cracked.
Got tge new fender on.
JoeDaddy
Gridley Ks
Got the lights cut-in and everything mounted back on the nose.
Now I'm re-considering the Harley Dark. What should I do to bring the front together? PTM Bumper? Grill options?
Also remember it's getting a 4wd axle slid under in a few weeks and I'm looking at these wheels.
