Towing with Kc tp38r
jvc1990
Blaine,Ky
How is this turbo working out when towing? How much weight are you towing,what kind of injectors are you using?any problems anybody.is this thing really worth the money?or are you just as well rebuilding the stock turbo using 360 degree thrust bearing,6x6 wheel.at what point do you need to change from 1.15 to 1.0 exhaust housing.just like to know how these turbos are working out.
MeTo
I installed one last September and think it's great for a drop in turbo. No EGT problems and get over 37 psi of boost. If you have a manual trans, i would talk to Charlie about ordering it with the .84 housing.
