Toyo open country RT ?
HBDELUX
Arizona
Dmstrucks02, I had the Nitto Terra grapplers prior to the Toyo MT, the Toyo RT is more aggressive then the Nitto Terra. Even being more aggressive tire noise with the RT is pretty much nonexistent.
The Terra Grappler was a good road tire. Not so much off road if the ground was wet (My opinion). In my use they did not clear mud/clay well enough at low speed. Prob not a big deal if you don't pull a trailer off road.
HBDELUX
Arizona
Dmstrucks02, I had the Nitto Terra grapplers prior to my Toyo MT, and now the Toyo RT. The RT is more aggressive then the Nitto Terra. Even being more aggressive tire noise with the RT is pretty much nonexistent.
The Terra Grappler was a good road tire. Not so much off road if the ground was wet (My opinion). In my use they did not clear mud/clay well enough at low speed. Prob not a big deal if you don't pull a trailer off road in damp or wet conditions.
Yellow1000
eastern MO
See that's where I was at lux, I stay mostly on road. But I wanted a good show tire and something with s little more floatation for pulling the gooseneck on the farm. But I'm far to picky about road noise lol hopefully my terra g2s will be good enough to get my loader around in the snow this winter
Sent from my iPhone using Tapatalk and ****.
HBDELUX
Arizona
Sorry about the double post.
Yellow1000, keep me updated I am interested in how the Terra G2 perform for you. I had the old design.
Yellow1000
eastern MO
I will post updates as I get miles on them. Got about 1500 miles on them so far with no sign of wear. They handle great to me so far. For only being a 65 psi load range e tire they hold the weight of my gooseneck just fine. And don't drive squirmy like I expected. The only thing I'm getting used to is the width and the grooves in the roads around here vs my narrow stock tires.
Boompats
Fate TX
Just put a set of 37" R/T's on my leveled 2013. I am happy with the noise level (or lack of) and it filled out the wheel wells as I had hoped.
AllGo'N'Show
West Canada
Are the RT even offered In a 37"?
35 is the largest on the site.
35X12.50R20LT 121Q E BSW 350190 8.5-10.0-11.0 75 18.9 34.8 12.5 3195 / - 65 / - N/A 598
37X12.50R20LT 126Q E BSW 350230 8.5-10.0-11.0 80 18.9 36.8 12.5 3750 / - 65 / - N/A 565
#350230 is the product code you can give your store
Barnbuilder
Waxhaw, NC
The 35x12.5x17 Mt is still on back order. Discount tire can only find 3 and my tires are bald. They can get a 285x75x17 which might look a little small on 8.5" wheels. How do you guys like the RT or the AT2?
ACFarmer
Eaton, Ohio
Just had a set of 33's put on my 09. I love them, look good and haven't had to put the truck in 4x4 with them yet. Coming from terra grapplers that in my opinion aren't worth the rubber they are made from. Was constantly stuck with them just doing normal farm work. R/t's are pretty quiet and seem to do well pulling the gooseneck as well.
mandkole
Northwest
pics? what size (305/55?)
F
Floorboard79
Guest
what kind of miles are you guys getting out of these rt's? considering a set for my 17'
