powerstrokin15
cal-tracs? or do they not count as "bars" lol
They are great for the track....lol
Wide Open race truck at the line so much that they launched the rear end of the truck dang near 2' off the ground
One thing about the Cal-Tracs is that when you let off the gas the bar no longer controls the axle wrap. It only controls the pinion when it goes up, not down like when you let off the gas, or put it in reverse. Does it work, yes, but on a DD that sees constant on-off throttle I would want to make sure the axle is not going to wrap no matter what.
Not as good as ouo... 1.64 baby.
:whs:One thing about the Cal-Tracs is that when you let off the gas the bar no longer controls the axle wrap. It only controls the pinion when it goes up, not down like when you let off the gas, or put it in reverse. Does it work, yes, but on a DD that sees constant on-off throttle I would want to make sure the axle is not going to wrap no matter what.
