Traction Bars
smcox1
Okay so I've been thinking about putting traction bars on my ccsb to help with shifting and I'm going to be building them myself and I've always thought they needed to be in line with the driveshaft but what do you do if you have a two piece drive shaft? Are they still only the length of the drive shaft? Or do you go all the way to the back of the transfer case? If so the things will damn near be parallel with the frame. I'm pretty sure the answer is to go with the same angle and length as the main part of the driveshaft but I want to double check with you guys.
driveshaft angle has nothing to do with correct geometry on traction bars however, they often end up very similar.
use a heim joint on the frame end and a poly bushing on the other.
i dont have the space to type how much goes into the calculations of how the suspension cycles and where the point of least bind is....
smcox1
So you can't use Heim joints on both ends? And this is why everytime I think about doing this I get overwhelmed and forget about it. It looks so straight forward and then everywhere you look someone is doing it a different way.
you can, but it transfers all road vibration and harshness thru the entire chassis. not ideal if you ask me...
joe d
monroe mi
Do yall leave them in a neutral state or add a littel pre load. I was going to also use 1/4 inch rubber between my frame mount and frame rail since ill be bolting my mount with 4 bolts or is the extra rubber not needed.
smcox1
The more I think about it they seem like they would always be in a bind whether you hit a pot hole, fill the tank up/the tank empty, or going through dips in driveways.
bluedge8
Champlin MN
IMO they need to have same or similar mounts or geometry as the front leaf spring mount. But really I'm speaking out of my azz, I don't really understand how they wouldn't bind most of the time
you want it solid mounted, not rubber in between
smcox1
Anybody else have any info? So far all we figured out is how to mount them LOL
smcox1
Helped a lot. I guess the thing to do is just to test it by loading it down and jacking it up.
old man dave
Petaluma, CA
You can use poly Jonny Joints from Currie Industries. That's the same company that make the custom 9" Ford rears. No clanking noises after extended use like the metal Heim joints.
cbf9703
Agreed. I've always used heim joints with the Teflon lining, but haven't done a set in probably 6 years.... will be trying these next time.
