cbrown
Just got a full competition trans with billet flexplate and mid stall hd converter from Elite/Rudys yesterday, put it in today. When we went to start it up, the truck starts fine, but it sounds like there is a nut bouncing around inside the transmission. It will only do it in park, once it is shifted into gear and loaded, it stops. But as soon as you take the load off of the transmission, it starts up again. The noise does not change any with rpm. Also, it jumps into gear hard. Any thoughts/ advice would be appreciated.
Thanks
Chris Brown
Thanks
Chris Brown
