So my 2005 CCSB 6.0 decided to leave me on the side of the road for the first time, I was in the middle of merging, pressed on the skinny pedal and the transmission decided it needed to downshift, I was able to hear anything as I had the air conditioning all the way up as well as the radio pretty loud but I could feel it shudder a little bit and then all of a sudden it was like I was in neutral. It won't move under its own power, I don't hear it grinding or anything while the truck is running, shifting through the different gears I can hear the motor sound like it is being put under a slight load but no where close to what it would be normally, fluid doesn't smell burned and has plenty in it. Am I looking at something simple or should I be finding a place to rebuild/replace the transmission?
