well i just got the trans together after replace the direct drive solenoid. the test drive was ok..a few funny up ****s but i thought that was just the trans relearning because i changed to a tow tune till i knew the trans was ok. the drive home from my buddies shop went good, as for the 60 mile ride to work the following day. about 10 miles into the ride home, witch was city stop and go traffic, i was no higher then 3rd gear. then i get to the on ramp and its running thought the gears, 6th comes then the convert locks and i get the wrench light. this time for the B solenoid. witch is the intermediate and OD solenoid..right now the truck shifts 1-3-5...
heres the question..ive been deleted for 7k miles now...running innovative extreme X for most of that time. i have yet to do a full throttle pull from a stop, i have been fairly nice to it. the fluid that came out when i did the direct drive solenoid wasnt burnt at all. the trans did have a funny shift ever now and then but it was doing that before i deleted. is it just **** luck that i lost this solenoid too. or should i be looking into other things.
i have studs plained for the winter months but i fear a suncoast built trans may have to come first :/
