Trans temp sending unit
17evanscolton
How do you hook up the wiring for the trans temp sending unit for I know where the unit goes but the wiring for it is there supposed to be a washer or something to hold the connector on or do you put the connector over the unit the screw it into the transmission
Sent from my XT1650 using Tapatalk
17evanscolton
dsberman94
Pennsylvania
I can tell you that isn't a replacement for the factory sensor. I can say that because you can't replace the factory sensor by itself.
