How much fluid do these trannys in a 6.4 hold and what's good fluid to use?
Nov 3, 2011 #1 Rmartin-97 New member Joined May 18, 2011 Messages 1,719 Reaction score 0 Location Mcarthur ohio How much fluid do these trannys in a 6.4 hold and what's good fluid to use?
Nov 3, 2011 #2 Mark Kovalsky Active member Joined Jul 11, 2011 Messages 1,187 Reaction score 8 Location SE Florida, USA Use ONLY MERCON SP or MERCON LV. A complete change takes about 18 quarts, but unless you have a heated flush machine you can't change all of it. The pan holds about 7 quarts.
Nov 4, 2011 #3 tbsimmons New member Joined Aug 5, 2011 Messages 2,221 Reaction score 0 Location Bakersfield, CA 7 seems about right. I have the Mag-Hytech and it took almost 15 and is said to hold like 8 more. Makes since. I would have 8 just in case.
Nov 4, 2011 #4 BFT Moderator Joined May 18, 2011 Messages 2,628 Reaction score 0 Location southern cali i changed out line to get rid of the external filter and installed a new elite trans. it took almost 5 gallons, FWIW
