Transmission questions
Athens, IL
10-4.
Was just curious how far you had loosened it for the 66mm (or 68?) inducer. Sounds like spool is not an issue however.
I loosened it originally for the non vgt. I've ran the 68 with a stock converter and it spools fine. It's a factory style vgt, so spooling isn't a problem. I've actually grossed 25k while using that 68vgt on my crew cab. Pulled it with no issues and reasonable egt's.
