Dustin F2504x4
My 09 6.4 has shudder issue when cruising around 65mph. It only does is when I ease into the throttle. When I put it in no power mode it will I have no shudder. It has a new transmission in it so Im wondering if its axle wrap or a carrier bearing? What should I check this shudder is a annoying problem need help fixing it.
Thanks Dustin
Thanks Dustin
