mclarengts
Im about to do some towing in the near future. My question is what should my tranny temps look like? whats normal, and whats high trans temps when towing?
You're completely fine up to 220°F. You can go as high as 250°F for no more than 1/2 hour at a time.
Yes, it did in the 60's. Fluid has been greatly improved since then. It doesn't start breaking down until it's over 300°F.I have no doubt in your knowledge, but regardless fluid starts breaking down at those temps and I personally wouldn't drive with those temps.
Is that a number that you just pulled out of the air? Why 215 instead of 220? The 220 is based on fluid and transmission material specifications and a lot of testing. What is your 215 based on?Tranny fluid will actually hold its consistency at higher heat for quite some time. I would say at about 215*F you should start to take caution.
I have never found one of those charts that even has a resemblance to reality.There are charts online that you can look up as far as the break down of fluid vs. mileage goes.
Probably not. 215°F is within the normal operating temperature of all Ford automatic transmissions. Reaching that temperature does not mean there is any problem. It means the trans is working hard, and probably is in a high ambient temperature.I did not say stop driving when you hit 215*, I said take caution. If you are hitting 215* you are probably having transmission issues as it is.
I figure this from the ATF specifications that I had access to when I was a Ford automatic transmission engineer. I no longer have them as I no longer am an employee.How do you figure fluid does not breakdown until 300*? Do you have proof of this?
I'm sure you're right about this. That doesn't mean that any of them would be damaging their transmissions.I'm willing to bet that every single person on this site would $hit their pants if they saw 300* on that gauge.
Once again I go back to the fluid specs. The fluid has to maintain a minimum lubricity even at 300°F.Even if fluid didn't break down until then, I am willing to bet with how thin it is your trans would not be happy about it at all, and it wouldn't be lubricating to its full potential.
I can't show you anything. It all belongs to Ford and I left it all there when I left.I realize you have a lot more experience with transmissions than probably anyone on this sight, but I just want to see proof of your breakdown analysis.
I don't doubt your knowledge, I'm just having trouble believing the temperature part.
Yes I was, from 1988-2007.If I remember correctly mark is/was a ford tranny engineer or something along those lines.
You can believe what I say without proof, or not believe it. It doesn't change what I know to be the facts.
When I was at Ford we supplied built 4R100 transmissions to an off road race team. They won the Baja 1000 and several other races running our transmissions.
During one race they had a cooler fan failure (the trans coolers were mounted in the bed behind the cab) and the trans gauge was pegged at 320°F for a few hundred race miles. We know that the trans actually got above 450°F because the solder melted out of the solenoids! The trans ran Mobil 1 ATF, which did get dark, but did not burn. The trans showed some signs of overheating, but it still worked fine and they finished the race.
