Tries to crank itself
koltenkemp7
2001 f250 7.3. Tries to crank with keys in my pocket. Any ideas?
Bluke
Colorado
If it's been snowing or raining. Mine even screwed up when there was dew on the windshield. The windshield is leaking.
WILD_PHIL
East TX
Dads truck started doing that earlier this year. Got so bad he had to start disconnecting the batteries every night. We chased the issue for 2 months trying to figure out WTF was wrong with it. It ending up catching on fire and burning underneath the hood down. Totaled the truck.
Sent from my iPhone using Tapatalk Pro
koltenkemp7
Sorry, been a crazy past few weeks. So it just tries. It never actually starts.
Well I hope mine don't catch fire.
Connor M
Youtube Certified Master Technician
Masshole
I'd look first at the starter wiring. Maybe a cut or a short somewhere is causing that. Then maybe ignition relay, or switch. After that, I don't know.
DEEZUZ
NO PUKESTERS
NWI
Check the central junction box for water. Leaky windshield?
Your more than likely replacing that box. It's probably water damaged
Dave_Nevada
Reno, NV
Try disconnecting the start switch wire from the solenoid mounted on your right hand fender first. This will indicate which direction your problem needs to be chased.
Generally speaking:
One direction:
Start Solenoid>Harness>Starter Solenoid/Plunger>Starter
(2001 uses the start solenoid on the fender and the plunger on the back of the starter)
Or
The other direction:
Start Harness>Junction Fuse Box>Neutral Safety Switch or Clutch Safety Switch (if present)>harness to Keyswitch>Keyswitch
Which direction will be revealed by disconnecting the control wire at the solenoid on the fender. That effectively splits the starter 'control' electrical system.
