Truck is dead
farmall99
McMinnville TN
Went out to crank the truck this morning and when I turned the key nothing happened. No lights came on on the dash, and there was a clicking noise coming from the PCM. It has been raining for two days now and my windshield has a crack in it, and I believe that it leaks now. Could the PCM be wet, and could it be dried out to where it could work again? Is there anything else that would cause this? TIA
Whytry
Memphis IN
I had this same problem, on mine I just let it dry and it would fire back up. I would look at your battery connections as well because I think that is my problem now.
farmall99
McMinnville TN
UPDATE: I got home this afternoon and checked the batterys. They were dead (less than 6 volts). The odd thing is that the truck started fine Sunday. We have the battery charger on it now, hopefully it'll take some charge.
farmall99
McMinnville TN
Yea driver side battery is shot, got some juice to it last night and it fired right up. Guess I need new batteries now.
