rake18
The truck is a 99 with the 7.3 The issue that just started and it only has happened twice now, I go to start my truck and the truck will just crank and crank and not fire. The truck has only been doing it after the truck has ran for 30-45 min then if you go out 10 min later sometimes it will start right back up or it will just crank. When it did not want to start i turned the key to the on position and let it cycle for 30 seconds and it fires right up every time. I have no clue what it could be like i said it's not doing it all the time so that's what has me confused. Any help or ideas what to check would be great. Thanks
