Tylerwilson
- Joined
- Jan 24, 2015
- Messages
- 9
- Reaction score
- 0
at a stop with the break depressed the truck will sometimes lug down and die, if i react fast enough and throw it in neutral it wont. also sometimes in reverse the truck will shudder and die. drives flawlessly other than that and has no problems whatsoever when moving. the truck has had the transmission replaced with elite diesel competition clutches, buillit input shaft, transgo shift kit, river city diesel low stall converter(1600rpm). took the truck in a few months ago and they tuned it with H&S *** on tunes(was stock tunes when problem started) and replaced the whole solinoid pack. fixed the issue for two months then it came back. Im thinking maybe the retune of the transmission fixed it? The first time the problem presented itself was after i replaced the upper belt tensioner(happened within two hours), is it somehow possible that the wrong tensioner(had both the tensioners but only put one on, maybe i put the wrong tensioner on?) could cause this problem. long shot i know but im running out of ideas.
Any help would be greatly appreciated!
