trucks at martys... again
I thought it could just be tuned around? My php tunes set the light but.dont defuel. Tw also.tunes it out.per testimony from several users. Is there any advantage to having it other than the purpose its name implies?
Dieselfever
Beaverlick, KY
I have always ran(and suggested) a boost fooler on both OBS and SD trucks. Sees the SD trucks don't care what kind you use, but one time I swapped out the regulator style for a blow off valve style on my '97(both were from reputable companies/vendors) and it was a dog. I mean like terrible throttle response, probably 75-100 hp short in the highest setting, made 10-15 psi less boost across the board. Switch it back and it was back to normal, IDK what the deal was though.
