jameson731
I Could use some help everyone. Thanks in advance to anyone who can help me through this, i really appreciate it. Quick run down of my truck, I have an 01 f250 7.3 truck has an intake and exhaust. Ive been running the edge evolution for over a year with no problems at all. After doing some reading and hearing how much better it is, i decided to get a ts 6 position chip. I plan on keeping the edge evo for gauges. The ts has stock, high idle, 50, 75, 100, 140. I received it today and started install. Well after reading to take the terminals down to the copper when cleaning them i did so. Went to start the truck in stock and it would only crank. Cel came on, edge wouldnt even read the hex file just showed error 150. I unhooked everything and tried again with the ts in high idle tune. The edge read the hex file and the truck started with it idleing at 1200. I tried to turn it to stock and it immediately stalled and the edge screen turned off. I turned the key off and switched the tune back to high idol. Turned ign on and everything turned on like it was supposed to. Flipped through the tunes while idleing and everything worked until i went back to stock and had the same problem again. With the ignition just in the on position each tune is hit or miss though. Some times it will run through its cycle and start. sometimes it does the same as the stock tune does and acts like there is no signal and the edge screen turns off and truck wont start just cranks. So.... After doing some reading i found that people found cleaning it down to copper caused the chip not to have a proper connection, and would have similar problems. Well i figured this could be the problem and had the computer re tinned(soldered) at a local electrical repair place. Solder job came out great, very clean job. Went to reinstall the chip fits nice and snug now. Got everything wrapped up and im still having the same problems as before. Not sure what to do now. This thing is starting to drive me crazy. Sorry for the long write up everyone. Also when i unhook the chip everything works like it did prior to installing the chip.
