alwaysdiesel
- Joined
- Feb 10, 2014
- Messages
- 34
- Reaction score
- 0
I'm in the process of finishing a HPFP replacement along with the gasket (shorted wires :fustrate I installed the turbos today with all new Orings and seals. I installed the low pressure turbo drain with the nipple side facing the turbo. I looked at a picture I took when I removed them and it was the other way around. Is it going to leak like this? I'm going to use callipers and measure the old one tomorrow to see if both ends are the same size. If they are, it technically should seal? Would like to know if I need to pull them off again before I drop the cab back down.
Thanks in advance, need an answer asap!
