Turbo Help
NRHX2009
Elizabethville, PA
A .70 housing is getting pretty tight on a 7.3L. Also, I think getting a t3 mount made would be a waste. It has the 71mm turbine wheel so I am assuming its the S366 that originally came with a t4i exhaust housing that was swapped to a t3 by river city. If you can, take the exhaust housing off the turbo and measure the diameter across where the center section of the turbo sits down in the housing. That will determine what exhaust housing you can go with. I recommend a .83 to .91 A/R t4 for stock injectors.
bruce
Middle east
I just got a feelin this is gonna end up costin more then if you would have just bought a whole kit from irate
Strokin7
Brownwood Texas
Bullseye double billet bat mo's with race cover S366 (66/71/.70)t3 open turbo.
Now what will i need to get in one the ole hog? Using T4 or t3
Strokin7
Brownwood Texas
Well for sure a .91 to 1.10 A/R T4 housing with 238's. The way it sits now you will pop that thing in no time with 238/100's and a .70 housing.
I have exhaust housings here ranging from .83 to 1.10 for s300 turbos.
You sound pretty knowledgeable about this stuff, me not so much, so if you can just give me a list of what i need to get to run it to its potential with those 238's
NRHX2009
Elizabethville, PA
for your truck or turbo?
For Turbo you need a 1.00 a/r t4 housing and t4 mount with plumbing.
For truck you need fuel system from tank sump to heads w/ regulated return
t500, srp1, adrenaline, etc for hpop
head studs recommended
910 valve springs
pushrods
And that about does it...
Strokin7
Brownwood Texas
I think im gonna go with t500 238/100 full force FRx headstuds and valve springs. Then eventually regulated return
And does anyone make that kit or am i gonna have to get it made? from irate or someone?
NRHX2009
Elizabethville, PA
irate makes a kit, Carson Stauffer makes a kit, and a few other companies too.
A regulated return is 100% needed for 238's to work hands down. The valve springs and head studs can come later.
