Turbos
Dzchey21
wyoming
im with you on this.. if a cheap turbo setup can be had and make all the same respectable power as tow/high/max powers for a cheaper cost them im all for it.. i mean i personally dont mind the idea of have a couple of 1,200 dollar turbos under my hood as aposed to a set that cost more than a down payment on a house lmao
in no way am i knocking elite either.. i understand quality and what it takes to be an inovater in this game..
Trust me unless its a dedicated drag truck you will spend the extra money for spool up
Dzchey21
wyoming
So can anyone tell me on these modded stock turbos is the only thing changed bigger compressor wheels?
Pick up the latest issue of diesel power, there is a really good section on what gets modified in the high and max power turbos
As far as tow powers yes just the compressor side gets modded
On high/max powers the exhaust side is moddified too, bigger wheels, more free flowing
I cant answer for what Industrial does
SEABEE08FX4
Montgomery TX
I'll have to wait till it shows up in the mail. I was just curious if the modded stockers had and exhaust housing mods to relieve back presure some. Max powers are way more than I need. I'm looking at the high powers hard though, but what do you sdi if your already running elites waste gate kit? Does it use the same set up or is the gate fed from tje port between the low and high pressure turbos?
I'd be interested to know what II stage 2 set specs are as well as WOP's compounds.
Dzchey21
wyoming
yes the bigger wheel and the housing mods aid for less restricion so some relief in back pressure
If you already have a gate your good, you will get a new pipe to run between the two stages, which is pretty important tuning wise, you want the low pressure to come in prettt quick with the settings on the gate, but not too eearly, but anyways your wastegate wont be... well...wasted LOL
SEABEE08FX4
Montgomery TX
LOL ok good, don't want to find out I also have to get a new gate kit. Still not sure on what direction to go.
White_monster
The great white north
I sold my gate kit and 6.0 manifolds and up pipes to upgrade to dual gates. The gate kit I had would've worked fine thou I just wanted everything to match, ya I'm weird like that.
Erikclaw
Central CA
I can say I had the tow powers and just upgraded to the HP compounds. The only other mod was 60 to 85hp injectors and 6.0 manifolds. The difference is like night and day! These things are mean for a DD, spools fast and when you get the gates tuned right it is a blast to drive. The Tow powers were great but i am glad I went to the HP's.
SEABEE08FX4
Montgomery TX
Haha my wife told me last night she knows I'm up to something with this money lmao.
Wish I knew an eta on the other compound kits.
CAT35niner
NJ
Im hoping WOPs kit wont be long. I think the remote mounted turbo kit will be tits and much easier to work on.
Erikclaw
Central CA
That is the nice thing about WOP's kit, when it is dialed in. Compounds sitting where they would be makes for ease of accessibility.
CAT35niner
NJ
Sounds like a plan as long as its not a dead idea. Is there a eta on the single kits?
